SALE
$100
Was $500
2-Tuner Tablo Device
Flexible. Compact. Adaptable.
Tablo can connect to your router over Wi-Fi, giving you the flexibility to place your antenna wherever you get the best reception.
For those who prefer to hardwire devices for the best possible stability and performance, Tablo can also connect to your router via Ethernet.
Tablo doesn’t need to connect directly to your television via HDMI, because it uses your home network to stream live and recorded TV wirelessly throughout your home.
Prefer a device with HDMI? Check out our other Tablo models.
Tablo’s attractive design blends into any décor and despite its compact size, it delivers free TV to any room in your home.
Tablo includes mounting hardware and simple instructions to save shelf space by securing the device to the wall.
Since Tablo connects to your home Wi-Fi network and televisions wirelessly, you can place it wherever your TV antenna gets the best reception.
Tablo features two (2) OR (4) onboard ATSC 1.0 tuners to record and stream free live broadcast TV signals from two OR 4 channels simultaneously.
Enjoying recordings and free live streaming channels doesn’t require a tuner at all.
Multiple tuners mean you can watch different live antenna TV channels on multiple different devices, simultaneously.
Tablo lets you watch live broadcast TV while recording another channel, so you never miss a moment.
Get to know the functions inside and the ports outside of your Tablo device.
Save all your favorite shows right on Tablo’s built-in recording storage.
Archiving technology automatically compresses recordings saved to onboard storage to maximize space while preserving picture quality.
Expand your recording storage by up to 1,000 hours of programming at any time by connecting a USB hard drive.
Recordings saved to external hard drives are stored in full, uncompressed quality.
Tablo supports USB-connected portable hard drives (USB 2.0 or 3.0, 1 TB – 8 TB in size).
We recommend Western Digital Elements and Seagate Expansion models. Other forms of storage may not be compatible.
© 2025 Nuvyyo USA, LLC. Tablo and Tablo TV are trademarks of Nuvyyo USA, LLC. All third-party trademarks, including logos, are the property of their respective owners. Screenshots of the user interface are for illustrative purposes only and subject to change.
This is an estimate only. Actual broadcast TV channels received may vary based on TV antenna location, reception, topography, and other obstructions. Streaming channels require an internet connection. View the Channel Details Report for specifics of each channel and to help determine what antenna is needed.
